Old 07-02-2020, 11:27 AM   #1
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by Jasper7821 View Post
if you shop around, they are usually around 125 each. I've just replaced everything once I'm in there, but I'm sure I spent money I didn't have to. The fork is the normal culprit for low-speed clunk and you can't tell until you replace it.
Look at the drop links and sway bar bushings as well, you can probably tell if those have issues from inspection. Dont forget, at that mileage, (100K?) your struts are likely worn also.
