Old 06-29-2020, 05:58 AM   #1
pilot4fn
Originally Posted by 9864ever View Post
Hi all, I just ordered a set of headers and high flow cats for my 2003 S.
I will need to extend the 02 Sensor wire a bit.
Does anyone know what gauge wire to use and any specifics would be great.
If anyone has done this before would be curious to know how it went and if you had any issues with thrown codes. Though I would imagine it could just be inaccurate readings due to the hi-cell cats (if that's the route you took)
Here's from my previously made post regarding the connectors and cable extensions.
"Here's the part numbers I used to hunt the connectors:
Bosch 1-928-403-453
Bosch 1-928-403-736
Each cable needs one of each plug.
I purchased these from UK, since I'm in Finland (no customs etc issues) - at least untill the brexit kicks in
Here's the link where I ordered those both connectors:
https://www.auto-click.co.uk/1928403453
Same can be purchased from all continents.
On top of the cables I have the white 8mm heat resistant sleeve. This size fits real well over the wires."
...and the actual post for the same:
What did you do with/to your Boxster today?
Hopefully this is helpful
Also, here's the link to post I did after installing the cable extensions and having driven a bit:
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
