Old 06-27-2020, 09:38 AM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by flmont View Post
BYProdriver,..back with the 1979-88 with the 3.0 Ltr engines you could install the 964 cam's and get a nice Bump in power..and so Iam curious if the same could be done on these engine's not really displacement just some extra kick so to speak,..But I'am sure computer controlled engine's are most likely set at there best performing range already
That's before Porsche was on such a tight budget & had been improving the same engine for 20 years. Installing a "bigger" cam increases high rpm power with a notable loss of low rpm torque which is what gets the car moving. Engine displacement size is the main factor that determines low rpm power to get you moving. Thus the phrase "there is no replacement for displacement!"
