Old 06-25-2020, 05:52 PM   #11
mnracing
Vacuum leak
Because it is on both banks, it has to be somewhere in the intake. Check your vacuum level at the oil fill cap, should not be more than 5 inches of water;with the engine fully warmed up. If it is higher, your AOS is leaking vacuum.
Thanks, Normally I find these things with a smoke test. I have been avoiding the AOS wrestling match. I have a new one sitting here so that's an option.
I'm not a fan of throwing parts at problems, so I usually diagnose a far as possible.
mnracing is offline   Reply With Quote
