Old 06-24-2020, 12:26 PM   #1
Homeoboxter
Originally Posted by DaveBBOXSTER View Post
Found this link with drawings of the entire Porsche variocam system and how it works;
https://rennlist.com/forums/996-forum/557016-how-variocam-and-variocamplus-works-a-primer.html
Just looked at the link and it got me thinking. EDIT: Knowing that the two cam actuators are different, is it possible that only one has a tendency to fail? Or this failure is rather model dependent?
I looked through a couple of threads on this matter and they were all about 2.7 engines.
I split one actuator from bank 4-6 (2.5 base), and it`s clearly different from the one pictured on the previous page in this thread (2.7). If you go back in the thread you can see both side by side. Mine had no problem with the large green O-ring, does not even have it. So is it because it`s model specific (2.5 vs 2.7) or because the one that usually fails correspond to bank 1-3? Can anyone confirm either this or the other possibility?
Homeoboxter is online now   Reply With Quote
