Old 06-23-2020, 03:33 PM   #137
Homeoboxter
I just read it. Pretty impressive! You should sell the kit for $1800
Also, I see you went with open bearings. You're confident they'll get enough lubrication? Don't take it the wrong way, I'm just trying to pick your brain in the event I decide to change mine.
Lol, just simple bearings I had machined to size. Actually, I made the groove for the circlip myself with a custom made grinder
Yes, I`m pretty confident. The IMS literally swims in engine oil. If you go back in the thread I posted some measurements about the oil level. Even though the level dropped a lot, the sprocket is still spinning in oil and should supply the bearing with splashed oil. Also, I added an extra oil channel as well that supplies the bearing with oil directly from the back, just in case, it`s pictured too, if you go back to that section.
