Old 06-23-2020, 10:30 AM   #12
gabedrummin
gabedrummin's Avatar
I did the ignition switch then ,the whole lock assembly and the lock assembly is easier .There are two small slotted screws that hold the ignition switch that are impossible to get at , had to get one of the kids to tighten then .If your small and don't mind being upside down with your head wedged in up under the dash you can do it .Good luck sir .Hope you have a little helper .
gabedrummin is offline   Reply With Quote
