Old 06-22-2020, 02:27 PM   #11
blue62
Originally Posted by Bronxboy View Post
Hello to all. I'm a new member and new owner of a 99 Boxster 986. I'm having a minor problem with my ignition. The key turns fine to start the engine, but does not return by itself to the accessory position. It seems that a spring has failed. Does anyone know if this spring is in the electrical part of the ignition or the mechanical. Feedback much appreciated!
You could spray some graphite, WD40, or other lube into the key slot and see if the does anything. Sometimes lube in tumblers gets old and gumby.
Simplest things first.
