Old 06-20-2020, 01:44 PM   #6
Jasper7821
On to the next item and seeing if anyone has a solution.
The passenger window when you open the door I can hear the actuator but the window doesn't lower that small amount to clear the roof. If I push it down it moves down about 1/2". Going up is fine as the door closes it moves the window up. When opening the roof the window comes down like it should. The prior owner was thinking maybe a loose bolt of something holding the window into the regulator.
And finally the brake lights do not work, they'll flicker then go off but that's it. He said maybe a dirty switch on the brake pedal. Since they flicker that means the lights work, just won't stay on when pushing the pedal. And both left/right and center lights all flicker the same.
Any ideas?
Thank You
Jasper7821 is offline   Reply With Quote
