I’ve used the behr coils for years. No issues, and replace the bolts, spark plugs and tubes while your in there. Build a tool to pull the tubes, I use a thin long bolt with a washer sandwiched between nuts and a cable pull on the front end. It grabs the back edge and you pop it out with a tug. Push the new ones in with a socket on extension. Search for various methods on forum for other ways if you like.
