Hi
I changed all four of mine (130k miles) for a low mile ebay set (originals). I tested them against the ones I removed and they were significantly stronger. I already had the inner CV joints undone for the gearbox removal, so at the rear just dropped the subframes (just 2 bolts). The real challenge when I did mine was undoing the pinch bolts. Calliper bolts were also a pain with one snapping.
I would keep away from any suspension harder than standard. The standard car is jut not a stiff enough platform IMHO.
Best of luck
Berni
