Porsche recommends to change the clutch on the Boxster S every 30K miles. In my case, I don't know how the car was driven by the previous owner so I will go with the recommendation. If you drive on the highway often and don't live in a city doing starting and stopping and driving up and down hills etc. then the clutch can last a very long time. If you live in a city, like the previous owner of my car did, then it is likely to last 30K-60K miles. If you autocross the car often, you might want to do it sooner depending on how you drive.
I am doing the clutch mainly because I am changing the oil gasket seal and the clutch will be exposed and easy to change. Otherwise, I might have taken my chances and waited until the clutch starts to slip/fail.
