I'm very happy I found this thread because just yesterday I went to check my tire pressures and seen a 360 degree wet circle in my front right fender plastic coming off the inside of the tire.
So I took off the tire and thought it was break fluid at first but finally figured out it was coming from the round plate the bottom of the strut spring sits in.That area was full of shock oil and running down to everything below then finally ending up on my inner tire throwing it out to the fender well.
I'm just like you Tony in that I only drive a little spirited around town and that's it.So I'm looking myself for something better than stock but keeps the same height and rides smooth as glass.
99 Roadster base / 5 SP Tiptronic
18" Turbo Twist wheels / Arctic silver W/Black leather Int
Rear wing W/Brake light / 47,000 miles
Side skirts / Bought from original owner
