Old 06-15-2020, 04:23 PM   #1
KevinH1990
KevinH1990's Avatar
Originally Posted by KC-CarGuy View Post
I seem to remember someplace that all cars roll off the factory line mostly the same, i.e. all wiring is there. Some things are just not hooked up and/or are missing the "on" button because they are NOT options.
Is it possible that an early Boxster without the heated seats option.... just need the seat plugged in and an "on" switch installed?
Thanks!
On my 1996 Infiniti G20, that appeared to be the case. I was able to retrofit fog lights easily because the wiring harness was already in place. I just bolted on some used fog lights, inserted the switch and relay and was ready to go
Sadly this was not the case when I installed heated seats in my Boxster. My theory is that the Germans value conserving resources and custom fit a wiring harness designed specifically for each car's options. The Japanese value "mistake proofing" the assembly process and use the same wiring harness on each car of a specific make and model.
I used Dennis Vogel's instructions to retrofit heated seats in my car: Dennis Vogel: Projects - Boxster Heated Seats This process results in an installation with the same appearance and operations as the factory heaters.
There are other options. This video shows how to use commercially available seat heaters:
https://youtu.be/2tAGcah3jsY
If you are well versed with automobile electrical work, you could probably combine the method show in the video with Dennis Vogel's work and avoid the cost of new seat foam.
I bought a pair of heated seats out of a wreck and used Dennis' instructions to wire up the factory switches.
Good luck.
