Old 06-15-2020, 09:44 AM   #3
gregkelley
My advice comes only from memory reading here and there passages from upon these pages. That said... if I were in your shoes I'd...
Blow some pressured air into the keyhole... where you insert the ignition key. There may be something that needs to be dislodged. IIRC... spray some graphie into the hole... insert and remove your key a few times... then try to start the car. Kill it. Remove key... do that a couple/few times... see if that doesn't correct the problem.
If it doesn't... I'd replace the ignition switch. I believe you can pick them up for less than $20. Go OEM. I don't believe it would be entire assembly.
Good luck.
Thank you for the advice. Odd that the electric switch would cause havoc with what would seem to be a mechanical problem.
gregkelley is offline   Reply With Quote
