Old 06-14-2020, 01:04 PM   #1
Spirit_RE
Just made a first attempt at disconnecting the ball joints. I can feel where the clamshell pushrod connects to the transmission crank arm, but I cannot locate the plastic ball joint (top connection) to remove it. I felt around for like 10 minutes and couldn't locate it. It seems like its accessible when the top is down (per the manual)..unfortunately my top is stuck in the up position. Has anyone figured a way to remove the ball joint without lowering the top?
Spirit_RE is offline   Reply With Quote
