Originally Posted by hstephenson
I recently replaced the heater control valve and OAS while i was in there. The car ran fine for about a week. now throwing 300, 302, 304, 306 misfire codes. can anyone give me an idea what to look for. cannot find any vacuum hoses loose.
2003 Boxster S
Misfire is usually caused by ignition related parts, Ignition coil, spark plug oil fouled from failed AOS ?? I believe the code numbers indicate which cylinder is misfiring so check cyl.# 2, 4,& 6 for oily spark plugs
