I just replaced the high tone with an OEM from Pelican. At a minimum, you will need to drill out the mounting holes for the studs. There is a bit of room in there. You are going to have to trial and error fitment. Regarding the connections, you will need to cut the connectors off and wire direct via solder or crimps. I don't think you need the relay, unless they aren't 12 volt horns. The OEM horns were $16 more, seemed like a no brainer to me.
