Old 06-11-2020, 09:27 AM   #12
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by pilot4fn View Post
Transmission mounts it is. Those are not leaking, but are in my opinion pretty much out of shape compare to new ones. This allows the header to downpipe flange bolt to touch to support frame on hard cornering. Also the right side does lean a bit lower compared to the leaft side - maybe this is why the rubbing happens only on the right side during 'fast' lefthanders.
Pictures show the rubbing point I found today and also right side transmission mount.
Thank you for your help on this! Now is time to order new mounts.
Then, I looked at the mounts to buy without the support brackts and came by this site offering the REIN AVT0307P mounts approx 1/2 price compared to next offering: "nsbomarket dot com". Have any of you ever purchased anything from there or is this just a scam...?
i am running those REIN, this is my second time on 2 cars. They are flawless.
NOTE: you will need a VERY large external torx socket to remove from the bracket, it was one size up from the set I have, so I needed help there.
