Old 06-09-2020, 04:54 PM   #1
mikefocke
Originally Posted by geekdaddy View Post
Recall reading somewhere that some folks in the UK are removing the IMSB flange and outer seal to inspect the bearing without pulling it, and if ok, allowing oil to more freely circulate around it after reinstalling the flange.
I'm not advocating this approach since I don't know much about it (and I chose to replace my bearing, which I found to be in near-perfect condition after pulling it). As you know there's a healthy debate out there about oil from the sump and whether or not it's adequate to lubricate an open bearing without a direct, pressurized feed.
But worth looking into and deciding for yourself before you replace the clutch...
I think that is the third gen IMS, sure as heck not the first two generations. And yours should be the fist gen. Dual row. Given the miles on the car, any idea the miles on the car when the bearing was done? If an LN sticker, they may be able to tell you.
