Thread: Green rubber
Old 06-08-2020, 03:36 PM   #26
JFP in PA
Originally Posted by gabedrummin View Post
Thank you JFPinPA I will keep an eye on it now that I have learned what I should be doing .I have read that the deactivation should be within plus or minus 6 degrees .Is that correct ? And at what RPM ? Still not really sure what spec Im looking for as far as whats good and whats bad.Thank you so much to all the Forum members and especially JFPinPA Thank you sir.
Cam deviation is a measure of how far off the cam position is from the ideal position. The actual cam angle should move from near zero to around 24 degrees if the VarioCam goes active with increasing RPM. Cam deviation limits are +/- 6 degrees.
And please stop calling me "sir"........
