Old 06-08-2020, 02:27 AM   #12
DaveBBOXSTER
Yes Eric-986, I am fairly sure the UK and USA wiring would be similar and that the 2 wire plug marked in yellow is not able to reach the LAMBDA sensor as it is at most 8"s long and if it wasn't connected the engine it would misfire or show fault codes. The most obvious reason is it is an obsolete plug as no SAI on my car. Here it is on my actual engine.
DaveBBOXSTER is offline   Reply With Quote
