Thread: Water Pump seal
Old 06-07-2020, 09:01 PM   #1
flmont
Water Pump seal
I had to replace my water pump,.when taking off the old one it had a paper seal and some RTV,.my new seal is metal,.the case is all cleaned up..should I use a tiny bit of sealant on the metal gasket or rely on the machined surface to be enough for a proper seal. Thank's !!.. Frank
PS. also changing to the 160 Deg Thermostat and it had the same gasket and sealant. !
flmont is online now   Reply With Quote
