I've been researching the same topic. My 99 Box had the original mount and the rubber was cracked and clearly on its way out. Reviews on the URO mount were ok but URO parts in-general had poor reviews so I went with Lemforder. Not sure if this is accurate, but read somewhere that Lemforder builds for OEMs as well...
Remember you will likely need to replace the side stops as well if (a) your new mount is 987 style and your old was 986 style and/or (b) the original side stops are in poor condition. Pelican sells them.
I had the old mount pressed out and the new one pressed in by my local machine shop. I ordered a Powerflex street insert and will reinstall everything this weekend. I'm using the insert because it should extend the life of the original mount and includes robust side stops.
