The lower tab is likely snapped off. I had to replace both sides.
https://www.pelicanparts.com/More_Info/98650474700.htm?pn=986-504-747-00-OEM
But remove the screw at the top of the grille and check in case it was removed previously and not refitted properly. The tabs must be inserted in the grille channels.
