you heard a pop? That probably is one of two things. 1. The push rod ball joint popping off the top. 2. the clam shell push rod popping off the transmission. Search the form for the emergency way to remove both and inspect it. Waynes book (pelican forum) has info on how to retime the transmissions if need be.
My guess is though you broke an end cap and now need to replace it (ebay $15).
