					Originally Posted by husker boxster  Not the cheapest solution, but I use a pair of jackpoint jack stands on the rear lift point.  You only need 2 as you can lift the car high enough from the rear point that the front will  come off the ground and I place a regular jack stand in the front.  The jackpoints have a wide base.  Once again, not the cheapest solution, but do we want to scrimp when it comes to safety? |
I looked at those, and they were nice and my second choice,  but if I were going to spend that much, might as well spring for a quick jack.
