Updates:
After having some time to mess with it this afternoon, here is the current symptom list
- Door locks do not pop from the dash button or using the key.  They key in the door does not actually lock the door even mechanically.
- Power windows do not operate with the console buttons.  They will jut up and down with door open and close as they should.
- Hood latches on drivers rocker are firmly locked
- Intermittently will start or not do anything.
The starting issue seems like it could be the classic ignition switch issue though I did replace that a little more than a year ago.
Is it possible that I got another faulty ignition switch and all of the symptoms are related to that?
