Old 05-31-2020, 05:55 AM   #10
BRAN
WALDMEISTER
BRAN's Avatar
...that topic never gets old
I have a pair of Hella LEDayFlex II and their IKEA style wiring diagramm...
Ignition on = DRL on
headlights on = DRL off
TASK: I don't want to run any cables inside to the switch, relay or fuses = All cables should be attached in the frunk area.
QUESTION: headlight low beam cable = Can I find it in that harness (s. pic)
switched plus = black/yellow (from the spray jet washer was used, I've read)
and the rest is no problem.
THANK YOU,
