Old 05-28-2020, 06:04 AM   #28
1PorscheBoxster986
A Porsche Guy
1PorscheBoxster986's Avatar
You are not the first and you won't be the last. The nightmare will be over soon. I have a narrow garage and I was physically pin between my wheel and wall to get into the wheel well from the passenger side. Follow the instructions given for the passenger side wheel well. I find that turning the wheel inwards as much as possible to gain more arm access helps. Like others said, you should re-route it to somewhere you find more comfortable to get to in case it happens again.
I believe the emergency trunk release cable on the driver side wheel well and I could be wrong is for UK models.
1PorscheBoxster986 is offline   Reply With Quote
