Old 05-27-2020, 06:32 PM   #11
MaxD
Originally Posted by rfuerst911sc View Post
I wonder if a small piece of metal tubing could be installed in the rear trunk on the front wall . Maybe 3/4 " diameter and up high . You sense a fire/smoke you pull over and grab your extinguisher . As you exit the car you pop the trunk and place the nozzle of the extinguisher into the tube and empty it . Either the fire goes out or you walk away knowing you at least tried . A simple rubber plug would keep under hood dirt and grime from getting in the trunk . Crazy idea ?
Yes crazy idea, you don't run back to a vehicle that is on fire.
The hand held is just to put out the field you just lit up.
The car burns.
PCA Intermountain Region Track Chair
SPB #50
MaxD is offline   Reply With Quote
