Old 05-26-2020, 05:20 PM   #4
rfuerst911sc
I wonder if a small piece of metal tubing could be installed in the rear trunk on the front wall . Maybe 3/4 " diameter and up high . You sense a fire/smoke you pull over and grab your extinguisher . As you exit the car you pop the trunk and place the nozzle of the extinguisher into the tube and empty it . Either the fire goes out or you walk away knowing you at least tried . A simple rubber plug would keep under hood dirt and grime from getting in the trunk . Crazy idea ?
rfuerst911sc is online now   Reply With Quote
