I have checked the fuse, it was not the issue.
Regarding the magnet, I think it is the electro sensor, that finds out when the pistol is in and opens the circuit in the bleeding valve. I thought that pushing the plastic tab will be the manual way to open the circuit.
Is there a way to check the sensor?
How about removing completely the bleeding valve and just joining two pipes that are attached to the valve
