Old 05-25-2020, 01:44 PM   #9
Aynsley683
Ok, so this happened today , searched on here found this thread as the key wouldn’t turn , would lock and unlock etc. but not turn in ignition.
Pulled on the steering wheel and there it went , ignition key turned.
So here’s the question , I’ve done the search and the wheels were straight , as it’s going into a garage and I’ve already done the ignition switch last week from the last time this happened .
What’s next on the list, as the search’s just pulled up ‘replace ignition switch’ ?
2003 986 base with automatic transmission , it took a 2004 ignition switch ,as that’s what came off. Farther in law said it had a battery drain of some sort but then he didn’t drive it often, so thought that was issue.
Aynsley683 is offline   Reply With Quote
