Old 05-23-2020, 11:27 AM   #2
Starter986
1998 Boxster Silver/Red
[QUOTE=kyporsche;617551]
I don't believe the wash had anything to do with it... unless you were spraying copious amount of water into the intake. My first guess is that your AOS went kaput. The first thing I would do is remove the tope AOS hose... give it an examination... see if it has a LOT of oil in it. A little is ok... a lot... I'd then pull the throttle body and see if it isn't flooded with oil. That may explain the no-start issue. Worst case sceanrio... you sucked a bunch of oil into the engine... and that'll require correction.
Do some searches on "white smoke 986 Boxster"... "AOS failure 986 Boxster"... you'll find of lots of information.
so the mechanic at my dealership got the car to start and now it sounds like the lifters are also toast, he quickly shut it down and we are going to move forward with examining the plugs and changing the aos
Man... I hope it's something simple like the AOS. Lifters toast? Keep us posted... we like closure.
Best wishes. Se you around.
1998 Porsche Boxster
