Old 05-20-2020, 08:58 AM   #3
husker boxster
husker boxster's Avatar
Pull the #4 plug and check its condition. If it's fouled, clean it up and replace. Swap the coil to another cyl. Clear the codes. Start it up and see if the misfire is still there. Check the codes. If the misfire code has moved to the cyl with the #4 coil now on it, you've got a coil issue. If the misfire is still on cyl #4, you've got either a bad plug or bigger issues.
1989 928 S4 5 spd - black
husker boxster is online now   Reply With Quote
