Old 05-15-2020, 12:47 PM   #1
jonogt6
Originally Posted by traveno View Post
Some pictures may help us. Sound like there's going to be fine plastic pieces in your coolant. I think Porsche designed these impellers to be fibrous because they anticipated this happening when a water pump fails. Better than having a metal impeller dig itself into the wall of the case.
I'd give that article a look-over. Then I'd flush my coolant and inspect it for those impeller pieces. I'm not exactly sure what you mean by a damaged crankshaft/crankcase? A picture of this would help.
A thorough flush and a new water pump should fix your problem.
Pity they hadn't been so insightful when they decided to fit a wheel bearing in the engine 😉
jonogt6 is offline   Reply With Quote
