I'm guessing as you say "shafts" you are talking about the splined shaft that passes through the hub and the axle nut torques onto? Based on my experience that every axle I've removed had it (4 cars and counting) this should be lightly coated with a COPPER anti-seize.
all the seals and rings are lightly oiled when replacing and voids are filled with bearing grease.
