Old 05-10-2020, 12:14 AM   #1
dak138
It's probably the OSVR reed contact which sits inside the bleeder valve just under your fuel filler. The bleeder valve has an orange circular face on it. There's a good article in pelican parts that shows you where it goes but there is an obvious recess inside the valve. Without it fitted, you may have a problem filling up. This is an issue that I've had for a while as my car doesn't have one nor can I find the wiring for it!!!
Sent from my ASUS_Z01KD using Tapatalk
dak138 is offline   Reply With Quote
