Old 05-08-2020, 06:34 AM   #5690
dsallean
Originally Posted by imhighlander View Post
Almost forgot...
Since I'm in there anyway, I ordered a 997 plenum and some new plenum boots to go with the 74mm 996 throttle body I ordered. Once the IPD intake tube arrives and I get everything back together, I'll also have a bigger intake to go with the new exhaust.
I simply can't justify the IPD plenum at (literally) 10x the cost of a 997 plenum. The 997 plenum is also 74mm to go with the beefy throttle body; it just doesn't have the sexy aluminum body and the machining inside. I'm sure IPD's stuff is crazy good and superior to a stock 997 plenum but I figure that 1) it's bigger volume than what my 3.2 came with, and 2) at 10% of the cost of an IPD plenum, the 997 unit will be "good enough."
Mind if I inquire about the IPD intake tube? I have all the same plenum and throttle body you have but have not installed them yet. Interested in that IPD intake tube but didn't know you can get it by itself.
dsallean is offline   Reply With Quote
