Old 05-08-2020, 06:24 AM   #785
Nine8Six
Nine8Six's Avatar
Originally Posted by amagalla View Post
How about lighting effects that change with the audio of the sound system?
We are so young, forever will, that's good Tony!!!
Originally Posted by rflores2323 View Post
There are systems out there already that work with LED's and Bluetooth.
True that, its all over here too and in several voltage, port to android, iphone, hand held, you get dizzy just looking at all those options. But none can do brake signal input, expand to dev's thinkies (k-line?), and none comes with a sexy CNC enclosure with a built-in quality IPS capacitive touch display
Thanks for linking-up, good catch I had that in mind too. We have them here in fact, 100% custom. Using a similar solution from a domestic manufacturer for an HMI active membrane switch (recessed push-buttons and clear window). Completely different alley though (i.e. automation system). You send them a *.AI template with the pantone colors and they ship you out your membrane in <48hrs. Interestingly enough, they cost X5 more (per unit) than that IPS display if you consider a small quantity... which is our case :/
Anyway. All brilliant ideas none the less, thanks for sharing those along guys and keep em coming.
