I'm doing an IMS change on a 5-chain engine and the cam lock situation was a little confusing to me. A lot of the tool kits come with a "c-shaped" lock and an "e-shaped" lock. Can see them in your original picture.
The c-shape lock fits into one of the camshaft end notches on a 5-chain motor. The cams on each head have a chain that keeps one aligned with the other so only cam must be locked (along with the crankshaft -- follow ALL the instructions).
On a 3 chain motor, I think the E-shaped lock is used. It locks BOTH cams on a head. The tool ends that fit into the cam notches are also thicker and won't fit into the cams on my 5-chain head. Somebody with a 3-chain motor pls correct me if this is wrong.
Originally Posted by tonythetiger
This just in from LN Engineering
"You are good to go. Only one side needs to be locked which is why there is only 1 in the kit. The smaller loc that looks like a "C" is the 5-chain loc."
I'm told it is the right side, facing the flywheel.
