Thread: Engine tilted.
Old 05-05-2020, 09:22 AM   #10
Qmulus
inveniam viam aut faciam
Originally Posted by Emerald View Post
Disaster bummer. Exposed everything and found the differential case broke off at the bolt. (of course this is after foolishly buying new transmission mounts). My nephew used to be an instructor and Wyotech and said it would be hard but thinks he can weld it, and add a metal plate for more reinforcement. If we do it I'm going to have him reinforce the other side at the same time. I'm going to do some more research to see if this has ever happened to anyone else before. I googled '986 differentials' and nothing but a 5speed came up. Any advice would be well received.
Wow, broken transmission case. That must have been quite a hit. That tab is part of the front half of the transaxle assembly including the bell housing and differential housing. I am wondering if the mount bracket or upper mount bosses are broken as well. To do that right, it will have to be removed and disassembled. At that point, you might consider just replacing the whole transmission.
Qmulus is offline   Reply With Quote
