Thread: Engine tilted.
Old 05-04-2020, 05:52 PM   #9
piper6909
piper6909's Avatar
Originally Posted by Emerald View Post
Disaster bummer. Exposed everything and found the differential case broke off at the bolt. (of course this is after foolishly buying new transmission mounts). My nephew used to be an instructor and Wyotech and said it would be hard but thinks he can weld it, and add a metal plate for more reinforcement. If we do it I'm going to have him reinforce the other side at the same time. I'm going to do some more research to see if this has ever happened to anyone else before. I googled '986 differentials' and nothing but a 5speed came up. Any advice would be well received.
Something must have been wrong with another mount(s) I can't imagine that such a small aluminum tab with such tiny gussets would be designed to hold so much weight that the motor would drop 2" if it broke.
Is that where the L-shaped part of the tranny mount bolts? If so, is the top bolt of that L-shaped bracket missing? That's the only way I could see something like that happening.
piper6909 is online now   Reply With Quote
