Originally Posted by Robert986
Do one need a Wheel alignment after this operation? I would guess an alignment is called for if you have hade the big alu plate loose (Whatever itīs called)
If someone knows, please enlighten us.
It is OK to pull the plate and put it back on while the car is elevated.
As long as you don't drop the car onto the suspension with the plate off you should be fine alignment wise.
PCA Intermountain Region Track Chair
SPB #50
