Ordered some bits for a busy weekend:
* Discovered cracked ignition coils when I attempted to change plugs, so new coils en route for install with new plugs
* Burned a hole in PS pressure line (contact with new header; doh!) so that's on order
* Plan to disassemble and clean intake since I need to remove left side to access PS line. "While I'm in there..." I'm installing 74mm throttle body and 997 plenum
* IPD intake hose and clamps also en route for clean install
Fingers crossed for a successful several hours in the garage this weekend.
