You say you have Motul brake fluid, how old is it? Normally if the pedal gets softer it's the fluid boiling, but if the pedal remains hard but the effectiveness of the brakes gets worse then the pads are fading.
I'd flush the fluid completely. Even if you bled the brakes, if you didn't get all the old fluid out that could be your problem.
