Old 04-25-2020, 04:02 PM   #11
Omes986
Started to chase down the fob not working/passenger door won’t lock/alarm control module doesn’t light up/two beeps gremlin and the driver heated seat not working issues.
1. Re: the alarm control module, took out seats, replaced 15a fuse just to be safe, opened up case, both sides looks dry as a bone. Put everything back, crossed fingers, turned car back on... still not working. Will start focusing in on the passenger door latch tomorrow. Only thing that stood out as odd was the passenger pan had two ground wires, but driver only had one. Normal?
2. Re: heated seat, passenger side works, changed relays/changed switches, driver side still didn’t work. As per one of the threads, tried the continuity test, seat back showed no current (seat bottom was fine), did the short circuit/splice wire solution. Put everything back, crossed fingers, turned car back on... still not working. Unsure of next steps here (in-car fuses are fine).
0/2 today, lol.
2001 Lapis Blue Boxster 5spd.
2011 Sand White Cayenne 6spd.
Omes986 is offline   Reply With Quote
