Old 04-21-2020, 02:02 AM   #1604
Evan_S
A while back, I bought an unused, parted-out Nine8Six headlight kit from a fellow Dutchman. Since the kit was already parted-out, it gave me an opportunity to modify a few things.
I used different angel eyes; 85mm SMD3014-led, 6.000k, with automatic dimming function (when lowbeams are turned on) :
Glued the lens and angel eyes using JB Weld and I added spacers between the reflector and lens holder (for extra security in case the glue fails and to get the lens perfectly mounted into the shroud) :
Shimmed the bulb (more about this here) to get the hotspot exactly centered:
Testing and levelling:
Next and final step: clean and seal the headlights..
Evan_S is offline   Reply With Quote
