Thread: Tyre pressures
Old 04-17-2020, 07:44 AM   #2
JayG
On the slippery slope
JayG's Avatar
Originally Posted by Blue99 View Post
Pick a set pressure say 30psi. Take the car on a long run and check pressures. If pressure has risen by more then 10 % original pressure was to low ~ if gone up by less then 10% original pressure to low. Will take some Time but you’ll find the correct pressure
Driving generates heat and pressures will go up from that 3-4 deg normally.
2004 996 Targa Tip
Instructor - San Diego region
